Warm Hubs...
Just got done doing the Birfields and the wheel bearings. To all who contributed to the faq for this, thank you! Even with the FSM, and the Gregory manual, I found the faq post to be the most useful resource...
However, comma, I have a bit of an issue. I did the 10 ft-lb procedure posted under the "Bearing Gurus" post. Drove the truck home, roughly 10 miles at around 35-45 mph. Got home, checked the hubs... and, they're warm to the touch. Not "burn your ass" hot, but warmer than I'm used to them being.
This a function of the bearings wearing in? I checked the pre-load, and it was about 15 lbs, after doing the 10 ft-lbs procedure. Did I err?
At what point do you start to get concerned about the temperature of the hubs? I'm thinking I have them a tad too tight. <sigh> I guess this means I get to dig back into those bastards, now... Joy.
Any insights, folks?
they will get warm from the heat of the rotors they are bolted to, I posted some temps soemwhere in the archive of a 30 mile run without using the brakes, IIRC hubs were just over 100F on a summer day,
warm will is OK, hot would give me concern
So, how warm is too warm? Normally, after a trip like that, they'd be a few degrees warmer than ambient. Last night, they were noticeably warm, as opposed to what they'd been in the past. And, I have been checking, lately, due to my overdue birf job...
Is it possible to take off the drive plates, and back the nuts off, just a few degrees, then tighten the lock nut back up? Or, do I need to tear the whole munging thing back down, and start from fresh?
On the other hand, is this just the new bearings wearing in? CDan sent me Toyota-marked Timkens, this time, and they were a stone bitch getting the races in. I used the FSM procedure for the pre-load the last time I was in there, as a stop-gap, due to a lack of time (wheels had noticeable play, and the nuts were loose, when I got in there) to do a full birfield/bearing re-pack. This time, I replaced the bearings entirely, not wanting to run on something that had been abused.
Never had so much trouble with the pre-load, on my 4Runner and truck. This thing is just a bear, to get right. On those, I just followed the FSM, and they were right, every time. The Land Cruiser? Sheesh.
