Wanted FJ60 distributor
Those can be hard to find. If you want a rebuilt one you may try contacting Jim Chenoweth in Ohio. He rebuilds and improves them, especially if you are modifying the smog systems.
I am running a DUI dizzy and passed smog with it. It has much higher voltage and I suspect a better timing curve.
Frank
To add to @elripster 's point... Even if you do find an OEM dizzy, the advancer diaphragms are usually shot and are NLA. Some people have been able to replace them with a single diaphragm advancer, but those will not work if you want the advancing with the HAC. Also, the single diaphragm is getting really hard to find as well.
For AHC, I just have a tick mark where my timing is normally set and one a few deg advanced where the AHC would have had it.
Frank
