Wandering 'Cruiser
I've been through most of the threads here on this subject and many thanks to all who have contributed.Thing is,when she (1990 80 4.2L) is stationery and I move the steering right to left the road wheel moves almost as soon as I rock the steering wheel.There is just a very small bit of 'play.Then I go for a drive and it can be like the Megafobia Rollercoaster at Oakwood.I really do not know where I am going to end up.At high speed,say 100kmh,she is more stable than at 50kmh.Sometimes she feels just right on an outward journey but can scare the livin s**t out of you on the return.Sometimes I wonder is it me but my other pony is a Scania R500 and the steering on her is consistently good.Have tightened the Steering Box a little.Have fitted new Knuckle Bearings.The Tracking is as it should be.Am I going mad?
bushings
If the steering seems "connected" ie: the tires move in conjunction with the steering wheel, than I would put my money on your bushings; check them all.
This happened to me on my FJ-62; albeit a different suspension set up, all the spring bushings had worn out, causing the axles to point
where they wanted to point. Of course, you have coil springs, not
leafs; but you do have a ton of bushings that can wear out, causing
a lot of looseness in the suspension.
Someone out there actually makes urethane bushings; consider those.
Good luck
