- Thread starter
- #21
WOOOOOOOHOOOOOOO!
VSV replaced. Took about an hour. Removed the brace holding the intake (bottom bolt was hard to get to). Ratcheting box end wrench got the first bolt. LONG extensions got the second bolt from underneath. Reached my hand in/under the intake to remove the hose that goes towards the firewall. Too tight. Got a long screwdriver and gently pried it off. Did the same for the hose going towards the engine valve cover. Gently pulled it out and disconnected the wires. One screw removed VSV from bracket. Cleaned tube with carb cleaner. Reassembly was just the reverse.
A bit tight and some small scrapes on my hands, but nothing to complain about. Especially since that one hour and a few scrapes saved me $500!
Haven't started it up yet, but will here in a bit..
Thanks to all for the input!!
. I took off a piece or two at a time, cut a new piece to replace it with and stuck it in position so I didn't get confused as to what went where. Some silicone spray helps if you can get it down between the pipe nipple and the rubber hose, but it also makes the outside of the hoses pretty slippery! I did have trouble with the hose that connects to the pipe running through the intake manifold (the pipe NLXTACY stores a drill bit in
). The piece of hose that runs from the bottom nipple on the manifold to the VSV for EGR decided it really liked being attached to the manifold. I ended up tearing the hose off and a piece stayed stuck to the nipple. I was able to use a long flathead screwdriver and some silicone spray to work it off the nipple, allowing me to put another hose back on.
banana job.
