VSV connector help
AJP
I am replacing the VSV for EGR ... without removing the intake or throttle body (eg from the side) ... is there some special trick to the electrical connector to the VSV ... I assume you squeeze the connector together so that it will disengage from the VSV male side that has the little locking tab ... I have been squeezing and can't budge the bugger or pry it apart -- been at it for 40 minutes... does anyone know how this works... I know somewhere in the 700 pages of shop manual they show how these connectors work but I can't find it for the life of me. Never had a problem liek this on any of the others!!
thanks
AJP,
I have posted a picture of the VSV for EGR sitting on the bench. If you can find that post then you should be able to see how the connector works. Advanced Search, 80-Section, author=Beowulf, Keywords= VSV pic* (maybe add 'bench') Let me know if you cannot find the post and I will try to SEARCH for you.
Found it: https://forum.ih8mud.com/80-series-tech/1837-engine-check-light.html#post13073
-B-
Thanks .. I'll look for the photo .. I have the new VSV sitting here and can see the locking tab on the male (VSV) side ... BUT the female half just will not budge! I have tried a screwdriver flat blade twisted between the connector halves and it still will NOT budge!
At this point I wonder if it isn't quicker to cut the wires and get the VSV out then resolder ...aaaarggh!
looking for the photo now
(the manifold has lots of very sharp aluminum flashing on it ... backs of hands are getting sliced to ribbons!! lots of fun!!!)
Thanks for the help ... much appreciated!!! Still cant figure if I am supposed to squeeze, pry apart ... or look for a "secret" hole to stick a small tool into to disconnect this thing.
It is thundering now...I am counting to ten before I do something stupid... will also see if pushing the connector together BEFORE squeezing and pulling will help clear the locking tab,,,
:crybaby:
Oh ... found the "secret" connector drawings and how they work in my Electrical manual....still no special "unlocking code" for the VSV connector.....am I that weak???
Thnx Rookie And Beowolf ...particularly thanx MUCH for digging up the photo... it nice to know that there are folks out there to get help from!!!
ITS OFF!!
Bxxtard!
Thanks for the moral support ...its a squeeze job ... apparently I am too weak!
It is Beowulf. :D
Here is a better picture of the connector. I found my old one on the work bench. The connector will have a locking tab that you will press toward the connector body and it will pivot and release the lock that goes over that little knob on the VSV valve.
-B-
Well I see you got it removed before I was able to post the last picture. Maybe it will help the next guy.
-B-
Thanks gentlemen (I will spell your name correctly Beowulf in future)... sorry I keep thinking of the were wolf ...there wolf..Frankansteen...etc ... anyway.
VSV done and belts and idler pulleys (both) now done....
radiator maybe "done" ... small leak ...BUT I think I disturbed the small hose at the top center while loosening the alternator idler pulley --- it had no leak before but a small "red crusty" at the junction of the rad and small hose... I twisted the hose gently out of curiousity and I think that disturbed the seal ,,, so after rearranging the spring clamp it "seems" to be ok and there was no visible sign of a crack or leak in the plastic neck ... I hope!
when replacing the VSV I also noticed a larger hose that feeds from the throttle body had come off the "three way" T that in turn also feeds one of the VSV for EGR tubes.....fortunately I saw it before buttoning up and reconnected it.. it was not a real tight fit FWIW -- I had this fleeting thought that it may have come off /loose before....
Idle is VERY smooth now... much smoother than before.....
I wonder who the diabolical bastard is that designed the alternator belt tensioner location... and the hiding spot for the VSV...and the connectors and the .... ah well still a great ride!
THANK YOU AGAIN FOR THE HELP ... AND MORAL SUPPORT!!
No problem. It is actually a very old tradition going back 6 or 7 years now. We have a member on 'mud that is dyslexic and he would frequently butcher names and words, including his own, and he particularly had problems with my name so I would spell if for him... over, and over, and over again. I would also help him with the spelling of his own name (4 letters!) after some good natured ribbing.
-B-
getting close to 10K posts bay-yo-vulf:flipoff2:
I'm astounded there are such die hard guys here, goes to show the quality and heritage of the landcruiser brand, and the helpful nature of it's loyal drivers. Been lurking and learning; once again, MUD rocks!
