VSS test
Oceanside, CA (Fire Mountain)
I'm in the process of swapping a 3FE from an 89 FJ62 into my 65 FJ45 SWB and am trying to sort out a VSS signal to the ECU. My plan is to use a 91-92 80 Series transfer case style VSS to supply a signal to the ECU. I believe they were originally designed to operate the cruise control. As many of you know there's quite a bit of failure on these units and they are NLA.
I have my hand on a used one and have followed the FSM directions on testing without success. I am getting a constant 12v reading when the VSS is turned when it is supposed to fluctuate from voltage reading to OPEN and back (pulses). Is that a typical reading for a failed VSS?
I do not have a VSS on my 65 gauge cluster like some of the later trucks.
Thanks.
Dom
So not a direct answer to your question, but at least throwing some info out. The VSS in the 89 FJ62 was built into the combination meter and was driven by the old-school flexible spiral cable that drove the mechanical speedometer. It's a simple "make-break" type sensor switch and you could test it with an multimeter set to the ohms position. I forget how many make-break "pulses" per revolution it made though. Presumably the 91-92 80 series 3FE uses a VSS that has same/similar electrical characteristics, since the ECUs should be the same or very similar. So you should be able to test your VSS using a multimeter. On the FJ62, one side of the VSS sensor is connected to ground. Is that the way you wired things up in your FJ45?
I looked into this same issue a few years back when @Cruiserdrew was thinking about swapping a 3FE into his FJ40. There was a very reasonable solution to the VSS issue at the time and I thought I had saved links/files/data for doing this conversion, but dang if I can find that info now. Sorry.
Wait... I found the file I was looking for. It was by Jon Stewart and discussed swapping a 3FE into a 1969 FJ40. Here's what he said about the speed sensor:
"I fretted over this for many months. Some folks said it wasn’t needed. Some said it was required. The documentation I had was vague. So, while at the boneyard I pulled the speedometer from an FJ62 and took it home. I then hooked up my multi-meter, set it to continuity/beep, and spun the speedometer. It pulsed four times per revolution.
"I had already acquired the VSS for the Autometer electronic speedometer. It consisted of a 16-pulse square wave VSS and a custom cable to connect to the transfer case. What I needed for the ECU was a reed-switch type VSS that produced 4 pulses. The ECU VSS runs piggyback with the speedometer VSS (Fig. 9). Again, my fretting was for nothing. The company that provided both VSS’s and cable was Speedometer Service Co., Milwaukee, WI, 414/463-6660"
Figure 9 mentioned in previous post. Top is the VSS for the Autometer speedometer. Lower is the VSS for the 3FE ECU speed signal.
It a simple thing-the 40 series dash in the upper part has an on off rotating counter thing that originally supplied the early smog timer thing. But the FJ45 didn't have that.
It sounds like Tom's solution is more elegant.
