VSS harness at tcase
Milwaukee
While chaning out the tcase juice this AM, I noticed that the red wire in the VSS plug on the tail of the t-case is pulled out of the plug.
How long is this harness?
Does it connect on top of the tcase?
Do I need to buy the sensor or can I just buy the plug/harness.
The plug doesn't seem to want to seperate from the speedo gear housing, so I am not forcing it.
No major symptoms, but even at low speed, once I lock the center diff, I need to shut down to get ABS back.
Can anyone offer me some direction?
I am sure someone has ripped that bugger off the tail section of the tcase on a stick or something.
Thanks in advance...
I'm not sure I understand your original post. Also, you never mentioned the year of your rig.
Are you talking about the speed sensor in line with the speedo cable/housing? If so, I can help you with that.
Curtis
