vr diag help
Jersey, 07740-Maryland, Harm City 21230
ill start this off with the regulator is not for a lc but it is a Toyota regulator, its off of a Toyota 2sdk7 skid steer. I figured that this would be the best place to get some info and knowledg. im pretty sure that its fried but just want to confirm that before ordering another one.
the alternator burned its self up when the nut holding the ring terminal for the b wire came loose. ring terminal burned through, burned up the b post, arced out on the alternator frame and eventually put a nice small burn mark in the connector with the f wire. the post was too shot out to just be able to throw another ring terminal on it and go so I had to replace it.
replaced the alternator and checked the charging voltage and found 18.3 at the battery, just a bit high. charging light in on while running and two others as well. disconnected the regulator and charging light is out, voltage dropped down to 14.something at operating rpm and down to 13.1 at idle. the repair manual has nothing in it for inspecting or checking the charging system so I really have nothing to go on other than an ewd.
im pretty sure that the regulator is toast based on my charging voltages plugged in and unplugged, what are the thoughts on this and am I correct in thinking that its toast. on a side note is there any way to repair these or is it even worth it?
