VOTE: Install Roll Bar or Patch holes?
1965 FJ40 Restoration progress... need your help....
Hi peoples... Almost finished with the FJ-40 's frame and body swap... The 63 I got had a roll bar that goes through the bed and was welded to the frame and the rear arms are bolted to the wheel well.
Should I put it back in when I put the body on the 65 frame tomorrow or should I do some fabricating and repair the bed holes and stay without a roll bar?
Which would lend more value to this '63 body on a '65?
Thanks Guy's!
I'll post progress pics tonight if I get a second.
The pics are screwing me up as you can tell below... any help here?
I guess the bigger question is what is your intended use of this truck?
If you are looking at building this and turning it, then clean metal and no roll cage might get you more cash to someone wanting something more original, and that way, if the new owner wants to modify it later and install a cage they can do it at that time.
If you plan on playing with it, I would not do so without a cage....but I have dumped my junk a few times and been on my head before......It happens.
:beer:
Check the Help section for the pics, good write up in there.
OK.
Here's what I did, clicked on your link, right clicked on your pic and copied image location.
Then enter [ img ]paste[/ img ] like that but not spaces.
I'm running FireFox and not sure how to copy image location with IE
Here are the rest... I don't have the energy tonight to do anything else...
Cool! THanks for the tip... :)
I never thought of that... I do it that way over at FM
