bj40green
Tssss, tssss
Hi Mudders,
Did any of you adjust the Voltage Regulator output voltage?
My output is a bit low +/- 13.1 Volt and I want it up to 13.8 Volt.
I found 2 procedures in the FSM's to do this.
The first one is by adjusting the gaps. This procedure is from a (printed in 1972) FJ40 FSM.
The second one is by bending the arms. This is from a (printed in 1978) BJ40 FSM.
I know, this for a 5 wire VR. Mine is a 3 wire as in the 1st pic.
This is how my VR looks.
When you look at the top where the spring is you notice that there is a strange bend in the spring. This looks different from both manuals. The pics in the manuals show a straight spring.
I think the PO has been fooling around with it, not knowing what he was doing.
Anyway, what I like to know is; How difficult or easy is it to do this adjustment and can you do this while the VR is on the fire wall or do I have to take the route to take out, make a little adjustment, put it in, check the voltage, if not ok take it out and so on, or shall I take the easy route and just by a new regulator?
If so what brand and part# do you suggest? I like to switch to a solid state one. If possible an adjustable one.
All suggestions and tips are welcome.
Thanks,
rudi
Thanks,
rudi
