Voltage Readings
Powell River, BC
I've had a few irritating starting issues lately. A bit of background: '73/74 fj40 with '69 chevy 350. Its been rewired at a friends shop a year ago, but has been sitting in the driveway since then. I would periodicly start it up, never a problem. Then one time I go to fire it up and the battery (which was bought new just prior to the rewiring) is dead. I charge it up and all is fine, and every once in a while its a little 'slow' starting. After a recent trip to a friends house to get the exhaust done and driving it around after that, it seemed to have this problem more often after its been warmed up. In all the many years I've had it, I never had heat starting problems. It sports the Advance Adapter fender well headers, which dont go anywhere near the starter.
While driving it around, I stopped at a store, whereupon restarting it behaved as if the battery was dying (RrrRRrrRRr kinda thing). I sat and cursed for a few minutes, flicked the key again and it fired right up. I believe my battery connections are tight and clean, everything there is new. The battery is located behind the passenger seat.
So I finally hooked a volt meter up, and after sitting for a week the battery read 12.7 (which from what I remember from mechanics in high school is perfectly normal).
Started it with meter still hooked up, dropped to around 10 and then peaked out at 14.6V while it was warming up (about 2200 rpm).
Blip the throttle when it reaches about 180 deg and the rpm drops to about 800, and the volts went down to 14.4.
I turned it off and the battery now reads 13.6.
I did notice that while its running, if I operate the signals you can see the amp gauge 'ticking' with the signals slightly.
any thoughts?
Charging system sounds healthy enough to me. Slow, almost dead cranking is very common when the solenoid starts to go. Starts fine usually but every so often it refuses. Dick around with it and she acts normal again (for awhile).
It's an easy fix to pull the starter, disassemble the solenoid, and repair or replace the contacts.
Take a moment and clean connector, with a file or sand paper, that goes between the solenoid and the starter motor. I assume that it's a ground since it is uninsulated. Mine was cranking slowly and after I clean this wire...success; it starts every time. Mine was also actually loose as well.
