Voltage Question?
Wilmington, NC
My right turn signal/running light works intermittantly on my 1972 FJ55. The running lights on both sides in back are fine as are the brake lights and headlights. Headlight hi and lo beams work fine w/ the stalk. The voltage reading w/ my tester was 23.8 volts on the left front turn signal/running lights and only 12.7 on the right side. The right side would not light the new bulb at that voltage. I can get the right turn signals to work only if I wrench the steering column housing at the stalk itself one way or the other. The left turn signal/running light works fine.
Additionally, I sometimes get a slight static shock getting out of my truck. I tried running a ground wire from the right turn signal to the frame and one to the negative post on the battery and it had no effect. I also replaced the double contact socket inside the right turn signal housing.
I am assuming I have a short in the turn signal stalk on the steering column.Would that cause the different voltage readings? Any help appreciated!
Before I did anything else I would check all the grounds. Every time I find a light not working I have traced it back to a rusted or dirty contact on the grounds.
