In drive, my 01 LX idles around 600 rpm or so but it occasionally drops to around 500. When at 600ish my OBD reader states voltage is around 13.5-13.7, but when it drops to 500-550rpm my voltage will read around 12.5-12.7. Weirdly it will tend to (regardless of AC or not) bump back up to a 600 idle for a minute or two on its own before it drops back to 500ish for a little while and then the process repeats.
I'm not sure if my alternator is dying and so the voltage drop is a result of that, or if my engine is dropping into an idle range that is unintended and so the alternator can't spin fast enough for it. I got the battery load tested to rule that out and it's fine from what I can see. Other threads explain the rpm at idle, but it's unclear to me if 500 is unusually low or just slightly so.
