Viscous Coupler or Front Diff Lock Partially Engaged
Hi,
I have ruled out any alignment issues on my full lock skidding of the front wheels on my 97 Cruiser with diff. lock and I really don' think it is the Birfields acting up. The next question is it possible that the front locker is partially engaged even with the light out or should I be thinking about transfer case issues with the viscous coupler? As I stated in my earlier steering binding post there is no mechanical noise or feel back to the steering wheel. What I get is a hopping or skidding of the front wheels when locked in a tight turn. Does it forward or backward and it is the same when making a right or left turn.
Pull the rear driveshaft and see if the hopping/skidding goes away.
The lockers cannot be "partially" engaged - they are binary.
I had a seizd VC, and the symptoms were exactly what you described.
I disagree with Ebag - I think you should remove the FRONT shaft to test it. If the front end still binds with the shaft removed, then it's probably not the transfer case that's the problem.
However... you need to engage the centre diff lock when you do this, or the transfer case will send all the power to the disengaged front shaft flange, and you won't move.
The stock 80 only locks the centre diff when in low range, so you need to:
1) shift the transfer case into low range, and drive it like that.
or
2) shift the transfer case into low range, then pull the transfer case fuse, then shift back into high range to drive. What you are doing is "tricking" the ECU to think it is still in low range, and it will tell the transfer case to stay locked.
or
Agree, attempting to drive with the shaft out and the center locked/unlocked will test the VC. When the center is unlocked you should feel slip, when locked should not, if there isn't a detectable diffidence the VC is locked. Warning with a shaft out and the center unlocked, shifting park will not reliably hold the rig in place, be sure to chock the wheels.
Eh, you can remove either DS to test the VC. I agree with everything else you've said. :cheers:
And of course there's only about a million threads on this already...
Hi,
What did you do to resolve your seized vc? I have tried looking up the part but can not find one on line. I was going to call Toyota on Monday for giggles to see how much this puppy runs. I'm guessing the labor to install an vc is much more of the issue than the cost of the vc. I have read a small bit on eliminating the vc from the transfer case. Not sure which way to go when I get the confirmed diagnosis. Have you ever heard of the steering locks causing a symptom like I have?
It's not cheap. If you really wanted the VC, I'd find a used T-Case as the VC's don't typically sieze unless they've been abused. Otherwise just pull it.
Your symptoms match a siezed VC very well, if you search the forum you will find probably 50 threads on it over the last few years....
Hi,
What did you do to resolve your seized vc? ...
Threw it away, and did the "7-pin mod" (lots of info if you search that phrase). I got a centre diff lock switch from a wreck, for like $10.00, and that was the only cost of the modification.
The VC is a sealed, self-contained unit. I have never tried to source one, but I bet they are a dime a dozen in the "parting out" section, if you really want to replace it. I understand that having one seize is very uncommon. In fact, I can only think of yours, mine, and maybe one other one.
Personally, I prefer the 7-pin mod because it allows you to control when the centre diff is locked, rather than relying on some device to decide for you (and specifically excluding the option of a locked diff in high range).
Hi,
This may show my ignorance but is the transfer case different for a Cruiser with the locking front and rear?
No, it's the same.
I only suggest removing the front shaft because if there is, in fact, an additional issue with the front axle, having it free from the rest of the drive-line is a pretty good way to tell.
Also, IMO - and in no way is this documented fact - I believe it is probably safer to drive something as big as an 80 in RWD over FWD.
When does the drive train bind up? When the vehicle is cold or warm?
Does it do it all the time?
My problem was a plugged and over greased slip yoke on the rear drive shaft. It turned the rear drive shaft into a hydraulic axe which put great pressure on the T-case. That caused the T-case to heat up and lock the VC. I only found this out after replacing the $2000 t-case.
A simple cleaning of the yoke could of saved me $2000 :crybaby:
Mine, it doesn't matter if it't hot or cold it will chirp the tires anytime I turn tight at low speeds, typically parking. So if i have the CDL switch, I can have the trans shop pitch the VC if it is bad? The 7-pin might come down the road but b.c I have the CDL switch I can lock and unlock and have no need for a VC?
the 7-pin over-rides the circuit that prevents the truck from being centre-locked in high-range. Even if you install the button, you need to cut or otherwise disable that wire. If you don't all the switch does is select between locked and unlocked IN LOW RANGE ONLY.
But I cannot stress how easy it is.
The wiring harness in the dash already has the socket for the centre diff lock switch - it's plug and play. Literally all you need to do is go into the kick panel, and disable that one wire.
But before you do any of this, you need to isolate your front end from the drive-line,to confirm that it's not a front axle issue. If it is a front end problem such as clicking/binding birfields, they will continue to bind/click even when the axle is disconnected from the drivetrain. If the front stuff spins/turns freely when disconnected from the drive-line, you know your problem is elsewhere (probably the VC).
Hi,
It seems to do it hot or cold. As I have previously described it only does it in full lock. Around corners or any other driving the front end feels fine. The skipping is like one of the tires will not roll freely. I wish I had a little more experience with this Cruiser but I just bought it last week. It was a one owner vehicle with good service history at the same Toyota dealership as well as TLC Landcruisers who probably did the OME lift. I'm going to take it to the only good 4 wheel drive shop in Sacramento and have them look over all the fluids etc.. I like you find it hard to believe that the vc failed since it is so rare.
Hi,
You have that backwards. :hhmm:
Fixed:
the 7-pin over-rides the circuit that prevents the truck from being centre-locked in low-range. Even if you install the button, you need to cut or otherwise disable that wire. If you don't all the switch does is select between locked and unlocked IN HIGH RANGE ONLY.
The transmission shop said the noise is from the front diff and you can feel it if you put your hand on the front cover. So I could still have a bad VC that caused the front to do this? I probably need a new front diff? Can I just change out the internals? I will have to pull the front drive shaft one of these days and test to see if the VC is bad.
My advice (and I'm biased because I DIY everything) is to take the truck home, pull the front driveshaft, lock the center diff, and see if the problem remains. I too had a failed VC and removing it cleared the issue right away. If your VC isn't the cause, then we can move on to diagnosing other components.
