Vintage Air
Here is the info. If I can get 5 or 6 guys including me the cost would be $850.00. This is just about cost for the item. This is the complete kit just as if it was purchased through VintageAir, everything you need. The shipping would be $20-$25 additional. Let me know, and I will get you the information needed. The time frame would be about 3 to 5 weeks.
Thanks
Scott
What are the opinions about taking out the stock heater - front and back?
I kind of like them - do they have to be removed to fit the Vintage air?
Yep, front has to come out. I suppose you could easily keep the rear heater, though.
You do have to remove the front heater, but VA makes the kit so it can retain the rear heater.
I am so glad to get rid of that BIG clunky heater. The VA runs quiet has 3 speeds and the valve really shuts off the hot water. I have the original 6cyl and have the vacuum lines connected right to the manifold but it lacks vacuum at idle for the controls to work properly. Could be something wrong on my end. With a fast idle the door drops down for heat and closes for defrost, along with the hot water valve opening and closing. Mine kit came with 90 degree aeroquip fittings I changed those to straight and use the existing holes in the firewall. The defrost tubes actually fit inside ( instead of around the outside) the original def vents. Easy install
I bought the 50615 VUH through BTB for 225.00 +25 for the metal plate to cover the firewall opening where the blower motor was. I think you can get them for 199.00 from VA
All and all a great investment. ;)
Those water I/O tubes on the bi-level are going in an odd direction for a cruiser mount (straight up to the dash) I do like the way the defrost tubes come off the side
Looks like i may get the new Servo Heater Valve Re-fit Kit 50507-VUA, and get away from the vacuum set-up
I am very happy with it. The blower kicks butt! The vacuum operated valve and heater door could be a problem for me at idle ( When I want to warm up the truck) so I think I might upgrade to the servo control, before I do I want to do a vacuum test and see what is what. In the pic on the PDF the bi-level I/O tubes seem to be going in an odd direction
For the people who have not replied to my PM's yet, please let me know as soon as possible. I have a few people interested, but I don't want to leave anyone out. I would like to order next week.
Thanks
Scott
skyshark186 I did a test this AM it was cold out I started the 40 and put the bolwer on medium with the door lowered for heat, 10 min the 40 was warm as can be. I think I will choose another vacuum port on the top of the manifold instead of the side with the pcv valve.
All and all a great unit! you won't be sorry
Hey, thanks for all the info man. You really went above and beyond. So you think stick with the one you got because of the I/O lines? I thought if i mounted the unit a little lower since its smaller than the stock one i could run one coolant line in on each side of the heater. That way it would look alright and still perform good. The reason being is the rep told me the other one is the updated unit of yours and has a couple nicer features. Plus if i can get it for the same price as the other one, why not? Let me know what you think. Thanks again.
And thanks for getting us a good deal man. Your really saving me freezing my butt of this winter. :cheers: :beer: :bounce:
Sure mu pleasure. Yeah if I was starting over I would order from this thread and maybe get the whole enchillada cooling and all:)
But to answer your question. I would go this the GenII Bi-Level and maybe get 90 degree fittings to loop back left right towards the firewall. The GenII has many new features beyond the simple one I have. My moto is by the best and cry once.
BTW if anyone needs 90 degree fittings after they get the unit email me I have 2 new ones I do not need
I am interested but need to know if there is a compressor available to work with a Chevy 350 serpentine belt set-up?
Nocents
