Video for radiator, water pump, starter replacement
Iowa
Hi, does anyone have a link to a video for replacing these parts that are prone to fail? I found one for Tundra water pump that probably applies to this also
Are these Tundra ones representative for the starter or it’s different?
2008 Toyota Tundra V8 iForce 5.7L replacing a starter and installment
Do you guys know of a video for starter and radiator?
Thank you
I did not find that series of water pump videos to be very helpful. FSM pages which I attached to another thread re: water pump replacement were spot on though. PM if you need them.
Thank you Mogwai, I found your post and saved it. Did you need to replace the pulleys or it was more for the piece of mind? I have not ordered them, I ordered the pump and the thermostat/inlet.
I replaced them because the belt was squealing/piece of mind. Those two parts were cheap in the grand scheme.
Now what I should have done was get after the starter and radiator but I had a hard time justifying swapping out these currently working parts on a young 2013.
I replaced my starter using the tundra forums/videos as a guide.
There are some minor differences, but mainly it's just getting in there to access the bolts. Not much room to work. Plan on usomg lots of extensions and universals.
The radiator is fairly straight forward. There are instructions to make it easier on the radiator failure public service thread.
