I just finished installing a 4" safari lift on my 55. Before i installed it there was'nt any kind of drive train vib. I checked rear springs to make sure they were the same length eye to eye and eye to pin as stock. I put the driverside on first, but when i tried to put the passenger side on the pin would'nt line up. So i dropped the drive shaft from the diff and installed the spring/shock/flipped u-bolts. Then i tried to install drive shaft. It was really tight so i checked the length and made sure that there was room in the inner splines. I had to rachet strap the shaft to get it in. Got it all done and took it for a test ride. I feel a vibration when its in gear, but not when the clutch is in. Nothing is out of phase. Would a 4" lift change the angles enough to cause this, or do i have to cut down the drive shaft ? Cutting the shaft does'nt make sense as the springs are the same length eye to eye, and are connected to a fixed point. Any advice would be cool. Mike
