Vibration driving me crazy
Baton rouge
Drove through water going 30 to 40 mph...now I have a vibration when I hit 60-70mph...I've had tires balanced and rotated twice, greased driveline and when that didn't work dropped it off at shop...they checked all u joints, both driveshafts couldn't find anything...they stumped, told me they can't find anything wrong...
help????
Wheel alignment? Highly likely and a cheap and easy fix.
How deep was the water? Any why 30-40mph? If it was deep water you may have gotten water in your differentials.
Make sure your lug nuts are tight. Maybe loosened up a tie rod end that was going bad? Driveshaft out of balance? Lost a wheel weight so balance is off?
Pouring down rain didn't see water, had tires rotated and balanced twice yesterday... definitely going do alignment next
Kind of a long shot, but could water have gotten into either drive shaft tube? That would certainly cause a vibration at speed.
Another thing to check is wheel bearings and rear axle bearings, a worn seal letting water in bearings will take them out pretty fast.
Check the temperature of hubs after driving on freeway, should be around a 100 if you haven't used brakes much.
Removed grease zerks on both front and rear drive shafts before driving home from shop this morning...zero vibration 0-90...thinking I hydrolock one or both drive shafts
Easy enough. Load them up with grease and be on your way.
