Vibration at idle
Alpharetta GA
Yes I am still trying to solve my roaring noise from the vehicle and a slight rattle vibration when letting off accelerator around 50 mph and going down a hill or faster. In the meantime my only tech that will touch a toyota in the shop solved my slight miss or bump at idle by cleaning my rotor cap and button and adjusting my timing and doing a BG injector svc( cleaning the throttle body and running a chemical spray down into the intake plenum and burning carbon out. Just thought I would share with those that have that slight bump or vibration at idle!:cheers:
Your roaring noise when you let off the gas sounds like a U-joint. Especially when going down a hill. CHeck it out. Thanks for sharing the other info:cheers:
No problem guys. I think the main cure was adjusting the timing. I have already changed the rear u-joints, gonna try the fronts next probably after I figure out this roaring noise. My mech buddy just bought a set of chasis ears so we are going to try those out this afternoon. I'll keep yall posted.:idea:
