Vibrating Slider Windows
Bethesda, MD
Hey All,
Ive been lurking on this awesome forum for about a year now, and I have found lots of info that helped me in my TLC upgrades. Anyways, yesterday I had amps previously mounted onto the floor of the trunk moved behind the PS trunk panel. The installation is great and still allows for the third row to be used, even with the sub in the car. I also had dynamat layed into both rear panels, and on the tailgate. Now my problem is that I am much more into seeking out vibrations due to the sound deadening, and I found that both of my third row slider windows vibrate and buzz significantly when the bass is turned up. The obvious solution would be to stop being the typical 18 year old and turn down the bass, but who wants to do that? ;)
Has anyone else encountered problems with these windows vibrating? If so, how did you solve the problem?
Thanks!
Mine did the same thing even without the killer stereo. New gaskets fixed it.
BTW...Welcome:flipoff2:
Haha thanks a lot. I just got the FSM a few weeks ago, and i've been trying to figure out what I should replace. What exact gasket is it? And how did you replace it? Was it difficult?
I'm a pretty 1 :banana: guy, but ive installed and filled a new fan clutch solving all overheating problems without any trouble, so I think I can handle this job with the right instructions.
IIRC, I removed both sides, cleaned out the channels and replaced the gaskets that are inside the channels. If you do a search on here, you will find a couple of threads that deal with removing the side windows. Definitely a :banana: job.
