Vibes when it's cold?
Drake Colorado
It snowed and is pretty cold on the front range this week. My '96 LX450 has been running great. Yesterday, after work I started my cruiser, let it warm up real good then took off.
Prior to this I had no vibes at all.
As soon as I started driving I noticed a pretty good vibration when I press the gas pedal. The SLIGHTEST acceleration would cause a vibe.
Do these trucks naturally vibrate more when it's cold and snowy? The vibes seemed to get better once I drove several miles. Wake up this morning and drive to work. Same thing - except maybe worse.
Any clues as to what is causing this?
Bone stock '96 LX450
Can you determine if the vibration is coming from the front or rear? It might just be a U-Joint. If it's starved for grease, or if it had a little moisture(which would be frozen before friction created enough heat to thaw it) in it, you could be getting some vibration until things got warmed/lubed up. Get underneath the truck, grab the driveshafts and see if you can get any play or clicking by pushing/pulling on it.
Be careful when ignoring vibrations. A board member had some vibes and eventually it was a front drive shaft u-joint which broke and sent the shaft flying towards the tranny, making a hole in it. Lots of work and lots of $$$ lost.
Yes, but, IIRC that was a constant vibration concern as opposed to one that only presented when really wintery out. In any case, I agree don't ignore vibrations but also don't perseverate with one that only presents for a few minutes when the rig is really cold. I never could track the vibe that the rig had when really wintery down and now that it is again cold I cannot find the freakin thing again so I've decided (very uncharacteristic of me) not to worry with it. HTH. :cheers:
