VIAIR 330C Compressor - New
Status
Not open for further replies.
AL Coast
New In Box with blank warranty card - $150 shipped in the lower 48 states. I prefer paypal, but would take a MO or other certified funds.
From the web:
The 330C is an extremely low amp draw, quiet running compressor designed for long service life in applications such as ambulances, air actuated devices and other applications. Features include a standard ¼” stainless steel braided leader hose with inline check valve and insulated wiring for simple installation. *Must be used with a 150 PSI or lower pressure, non-adjustable pressure switch when used with an air tank.
• 12-Volt
• Permanent Magnetic Motor
• Duty Cycle: 100% @ 100 PSI
• Max. Working Pressure: 150 PSI
• Amp Draw: 12 Amps
• Min. Ambient Temp: -40° F
• Max. Ambient Temp: 158° F
• Dimensions: 9.00” L x 4.00” W x 7.00” H
• Net Weight: 8.00 lbs.
Aside of the brand name, is this any different (better) than the MV50 deals Costco sells?
do you mean the MV1050?
good luck finding any actual real-life specs on those. people seem to have good luck with them, but you always get what you pay for. if they don't skimp on engineering, then they skimp on materials - or both - to get the prices that low.
if you're looking for a compressor to fill tires (not all that critical), then it's probably a good one. if you need one for an OBA to operate lockers (very critical that it works when you need it), then there's no way that i would trust one of those 100%.
SOLD!!!
Status
