VGRS + other weird stuff
Atlanta, GA
Hello, I've read through several posts here and also searched the web. I'm having different issues than any other thread I've seen so far. My VGRS light is on. I've gone thru the normal fixes (switch the multi pin, disconnect the battery) The light is still ON and the vsc & vsc track lites are on as well. The weird part is my electric locks are not working, neither with the key fob OR WITH THE SWITCH IN THE CAB Also, the AC is not in it's normal ON and Auto selection when I start the car. I have to hit the Auto button and all is well. Seems to me this is an electrical issue of some sort that has come out of nowhere. Any thoughts??
any signs of water near your left foot on the carpet or if you look up under the dash? Has it rained lately? Have you washed it? Wondering if maybe roof gutters are clogged or maybe a breach in the windshield molding/sealant.
It's been a pretty wet season here in GA but I haven't seen water on the drivers side. I'll double check tho. Are the symptoms I mentioned above normally caused by leaking drain?
Thanks
OK, now I just realized the mirror adjusters are not working. They will fold in but not adjust. Crazy
