This is on my 94 80 series. My intermittent wiper mode does not work. When I put it in that mode, it just acts as if it is on low. Low and high work normal. However, in all three modes when you shut off the wipers, they stop right then and there. They don't go down to the bottom of the windshield before they stop.
When I hit the rear washer, it only sprays the front. I am guessing diverter valve everyone talks about. Can someone please post a picture of said valve? PO has moved just about everything around, and it appears as though only the front washers are hooked up, but I am hoping I might still have the valve somewhere. Speaking of which, where is it supposed to split off to go to the rear washer, and where is its routing through the vehicle?
Rear wiper did not work at all, removed rear panel and found harness unplugged. When I plugged it in with key on but wiper switch off, it instantly started, and continued to go. It only stopped and the rear switch acted normally when I had the front wipers on low or high.(if I remember right)
Anybody encountered any of this stuff? Just hoping someone has before, and can point me in the right direction for an easy fix, before I dive into all the wiring diagnosis. Thanks in advance.
