very strange a/c behavior...
Abbotsford
I seem to have a mystery a/c system. Sometimes my a/c blows ice cold, and then after I drive for a while, it starts going warm, and stops blowing cold altogether.
Other times, when I start it up (vehicle is cold) it blows warm air (doesn't work at all).
Other times, it starts out cold, and stays cold throughout the drive. Anyone know what could be wrong?
Nobody has any ideas? It's supposed to be 86 degrees today, and over 90 on the weekend! (yes, BC can get hot too...)
The AC will cut out if the engine starts to overheat. Check your coolant level to see if the engine is using any. Could point to a problem in the trucks cooling system, could be the head gasket...could actually be the AC system.
Your symptoms indicate one or all of these in combination:
1) Your evaporator could be freezing up. When it starts to go warm, while driving, turn it off, wait about 3-4 minutes and turn the AC button back on....On a hot day, if the evaporator was freezing up, turning the AC off and letting the outside unconditioned air flow through the air box will thaw the evaporator. Turn it back on and you should have cold air. If this happens, you need to go to 2;
2) Check your refrigerant charge. It may be low or high
3) AC is affected by the automatic cut out (safety feature) due to the truck running a tad on the hot side
What BHM said....
Search for it, your symptoms are exactly what many others have posted in the past. In short though, if you are not overheating, and your refrigerant and compressor check out fine, you likely have a bad/dirty expansion valve.
Ok, so I hope I didn't really screw things up. I tried to put in some dura-cool (trust me, it worked great in my previa, ice cold) but contrary to their website, it doesnt mix very well with the r134a fluid. Long story short, I overloaded the system, my compressor started to vibrate badly anytime it would kick on (which would happen once every 3 seconds, and then off).
Ok, lesson learned. I brought it to the a/c shop closest to my house, and he measured close to 700 psi on the high side (3x what it should have been) is what he told me. Then he fully evacuated all the fluid in the system. Now my compressor seems to be kicking on and off normally, but it's empty of all coolant.
Ok, here's the twist. He tried to load 2.5 lbs of r134a coolant into it, and the pressure was back up to way above normal again, so now he's saying there's a plug somewhere in the system. After that, he re-evacuated the system and now I don't have any a/c at all, instead of a weak system.
I guess I'm stuck with a big a/c repair bill now.
Or any other ideas?
Replace the expansion valve, or whateverthehecktheycallit. It's something of a pain, but not too bad. I had a similar problem, I did the above plus flushed the system, which to do correctly entails replacing the condenser- making it a considerably more expensive job. My condenser was straightened after being involved in a wreck, so I felt better about R&R'ing it. Probably didn't have to. The advantage to flushing the system is being able to put in the correct amount and type of oil and coolant by volume rather than pressure. Pressure fluctuates due to outside temp, volume not so much.
So if you're super anal, replace everything. Cheap route, expansion valve/orifice. Or something in between.
-Spike
-Spike
I don't know where you got that you should replace the condenser after a flush, but they were blowing sunshine up your skirt. If you do a flush you should replace the TXV and the receiver/dryer. (And the part that failed requiring a flush to begin with)
Dave
You can't flush the condenser. It's simply not possible to get all the oil and residue out of it. Like a radiator, the flush chemical will take the path of least resistance, leaving much behind. I came to this conclusion after a bit of research, as I really didn't want to drop that kind of coin just to get a 'clean' system. Flushing the system usually isn't necessary, but I got my truck with 175,000 hard miles on it, having been rebuilt from salvage status (it got hit hard, from more than one direction) and I had no idea what jackasses had been in there or what they'd put in there, so I felt a flush was prudent.
I have no idea what a TXV is, but the dryer and all o-rings were replaced as well.
-Spike
Have him check the charge. It sounds like too much freon to me. My 92 only calls for 31.5 ounces according to FSM (just less than 2 pounds). In addition, I think there is a calculation for replacing 134a that calls for a certain % less than the R12 amount the FSM calls for. Have him check. I charged mine with 404a (MP66) which is a direct R12 replacement and it calls for 80% charge. Consequently, I added 25 ounces.
Hi pressure cutout is around 450. Have your AC person adjust the charge so it does not go too high after the freon equalizes in the system. It may take 10 minutes of operation at 2000 rpm w/ AC on high in recirculation mode for the freon to get distributed within the system and the pressures to come down near normal operating range. Mine hit high pressure cutout a few times after recharging until the refrigerant got distributed throughout the system correctly.
2.5 pounds sounds like way too much refrigerant, and 700 psi is way too high a pressure. It should have cut out well before then too...
Ensure you replace the AC dryer along with the expansion valve. The valve freezes due to moisture, and if you don't replace the dryer, it won't dry the air, which will cause your valve to freeze up again.
-Spike
The condenser is just like your intestines, one long continious tube, not at all like a radiator. if flush solvent comes out then it is clean. It has to be one long tube to allow the freon to condense to liquid form from high pressure gas out of the compressor.
TXV= Thermal Expansion Valve
Dave
You bastard. You made me get up off my cushy chair and go check. Fortunately for you I have the easy-view setup on my rig (no grill) or I'd be huntin' your azz down on a trail somewhere and give you the evil eye.
My particular 80 series has at minimum 3 tubes coming off the inlet side of the condenser. So, more akin to a cow's intestines, as I assume they might have multiple paths. Before you insist that you're correct (and you had me believing you until I took the trek out to the garage), go look at yours. :D
Passenger side, mid height, might even be the outlet tube now that I think of it, but that's neither here nor there.
-Spike
