Valve Noise under light Accel or Decel?
So Cal Mountains
My searches haven't yielded any results to match the problem I've got. Hopefully someone here has an idea of what the problem might be. I recently did the headgasket on my 95 FZJ80 and now notice a noise that I hadn't heard before. I now have, what sounds like, a valve ticking noise. It only occurrs after warm up and under either slight accelleration or slight deceleration (part throttle) and is most noticable from 2-3K RPMs. (I have heard it a little lower and a little higher than that, but that is where it is most noticable.)
When putting the head back together I did reinstall the valve shims in their original locations and checked the clearances. The feeler gauge for the low end of the clearance was tight, but it fit. The thicker gauge wouldn't fit between the cam lobe and valve shim at all, so I figured it was good.
Would the valve to shim being a little tight cause the ticking sound?
Also, under the conditions I have described, is it possible that what I am hearing is something other than valvetrain noise?
It sounds too light to be predetonation and isn't happening under heavy engine load.
Any ideas?
Thanks
Bueller........Bueller? :meh:
Well at least this wasn't a question answered in five seconds with an easy to find thread that I missed during my search.
Anyone have an idea?
I thought about that, but have not yet eliminated it. My experience has been that they are usually most noticable under heavy throttle, but I'll look into that some more.
Thanks
