Valve cover
Cary, North Carolina
Newb here...I've gotta 91 landcruiser and I was doing some routine tune up stuff and was swapping out the pcv valve and parts of the grommet fell into the valve cover. I need to adjust the valves anyway, so I attempted to remove the cover. The problem was the wiring harness against the firewall jams up all the clearance and I can't seem to get the rear end of the cover high enough to clear the valve train. Is there something I'm missing? I've already disconnected god knows how many hoses to get to where I'm at. The wiring harness only moves an inch or two...:frown:
Hmm...
Don't recall the wiring harness being a problem.
I don't have my rig here to take a look, but there's something else back there that's a good idea to remove to get more clearance. The bracket holding the throttle cable to the throttle body, or something.
If no one else chimes in I'll take a look when the wifey gets home. :lol:
What all have you removed so far?
Welcome,
Curtis
91FJ80
Can you see the piece that dropped in? (a flashlight might help). Is there a little shelf that it is sitting on? I don't recall if there is a shelf under the PCV for that year; it is just about 1 1/2 inches below the top of the valve cover. ie: it does not drop all the way down into the valve train area with the shelf in place.
I fished out my broken piece of grommet out with a pair of narrow needle nose pliers through the PCV hole in the valve cover; painless.
G
Thanks to both of you...I eventually got it off by getting a friend to pull off the cover while I held the wiring harness down against the firewall. G - mine did have the shelf you were talking about, but I had jiggled the valve cover to where I couldn't get to the pieces.
Thanks again and btw this is an awsome site....I've answered a hundred of my own questions by just reading the posts!:)
