Valve clearance adjustment on rebuild?
melbourne, Oz
I have only adjusted valve clearance once before on my running 2h before, seems to run ok. Best fuel economy of late is 11.3km/l.
Now on the new 2h I am rebuilding I did not notice before or probably did not take note, but at tdc, the two front rockers and pushrods are looser than the others. All valves are cleared to spec, in / out, when at tdc and at 360 tdc.
Then also , spinning the crank 360, The opposite rear two rockers and pushrods are loose and the front two are not loose.
I have re-checked the clearances 3x.
I realise the gap between the cam, lifter and rocker do need to release the tension, this is the job of the cam. Also, once the oil pressure is built when the engine is running it creates the 'push' upwards against the lifter.
I installed a noordeman performance ground cam.
Is this normal to have two loose rockers from two loose valve push rods at all times?
Would explain why diesels have the characteristic clacking noise.
The cylinder that is at Top Dead Center of the firing stroke will have both valves closed so they should be at the valve clearance spec. So yes they will be loose compared to the others that are on the lift of the cam lobes.
Hello, wondering if you could help me...I'm doing a head gasket swap and have to take off the rocker assembly, do you have measurements for valve clearances when the engine is cold? Or do I just reinstall the assembly run the engine for a few minutes then adjust the valve clearances ? Cheers
Set the valve clearances to hot specs, then once the engine is running you can check them again when hot.
Check to see if there's an FSM for your engine in the RESOURCES section in the drop down forum menu.
Some engines, valve clearances need to be checked and adjusted when the engine is cold
