I have the pinging also, Ive always run 87 octane years, with zero problems, I had the 401 code show eventually and fought it hard without just replacing parts, cleaned the throttle body, all the vsv and every other switch and check valve that can be found in the archives, got the code to disappear, but still shortly after the engine arrives at operating tempature the off idle ping returns. I personally think its an emmisions issue in addition to carbon buildup on the pistons and temperature, I also think there related. Why, because under a lot of towing stress the engine will overheat a little, which increases the ping. So now, is it a cooling issue, carbon buildup or emmisions, hmmmmm? Couldn't hurt to put in a brass radiator. of course my is old but would it fix it?? I did however find that I needed to replace the clutch fan with OEM, thermostat with OEM, flushed cooling system before that, cleaned fuel system with seafoam cleaner, all parts that could be disassembled plus any emmissions running it through the tank. Increasing the octane is an option, but to think the vehicle has ran so well over the years in the heat of summer pulling my boat on 87 leads me to believe there is another option, a real fix. thanks for any input.
