Valve adjustment, 94 LC
Just finishing up a HG. Hopefully the valves won't be out of adjustment to bad. I do not have access to shims so it my have to run for awhile before a recheck on the clearance.
How long/far before a recheck is recommended?
How much out of specs can it run?
Thanks
Don
Thanks
Don
Shims are cheap. Check Sears or other tool stores.
These shims are Factory only(at least in the USA). This shim is used on one engine only, I have looked recently and in the past for aftermarket shims in this diameter and have had no luck. Maybe some one will have a lead on where this specific diameter shim can be found beside the factory.
As for how long, you can still check them once it is assembled, before running the engine.
Exhaust should not be tight, Intake can run a bit tight for a short time. Performance will be lost if too loose.
Worst case if you run a engine with too tight of valve, you will need to pull the head again.
So what is too tight.
I would never run a engine with the exhaust tighter than .001-.002 out of specs tight.
I would never run a engine .003-.004 intake too tight.
I would never run a engine with zero lash, unless that is what the spec call for.
So do you have a idea of what your valve clearences are and want to post them?
Did you have valve work done or did you just replace the gasket?
Are you following the FSM procedures?
Thanks for the info.
I have had the head checked, new seals, valve grind, deck checked.
I have a Haynes book and hope it follows the FSM procedure. Plus I have you all.
I'll be measuring all the shims before mounting the head. Keeping them where they are to start. Do they have the thickness stamped on them? If they are not worn off.
Does the clearance need to be checked after so many miles?
Does the Head need to be re-torqued after so many miles?
Put the head bolts in dry or with a bit off oil?
Thanks to all
Don
Don,
Are you sure the machine shop that did the valve work did not adjust the valve clearance for you by machining the valve tips and moving shims around? That's fairly common, though sounds like you have the shims out, so.... Shims are not marked.
Don't worry about rechecking the valves unless you have reason to believe something's amiss. No head retorquing. Head bolts should have the block threads cleaned and blown out (I recommend a thread tap since the threads will have crud from cleaning the gasket off). After ENSURING there's no oil/liquid pooled in the bottom of the thread holes, lightly oiled bolts is the way to go.
Thanks for the info. I have not taken out the shims myself. I'm sure the shop did just to do the work. Hopefully they are back in the same place. The shop did not mention if they did any adjustments. I'll be checking everything in the morning and start assembly. I've done shims on other vehicles so I'm not unfamiliar with working with them. Should be fun.
Cleaning and prep work is the tough part.
Thanks Idaho
Don
What state did they return the head to you in - cams in place? If so, I'd be surprised if they did NOT adjust the valves. If they returned the head with the shims in a bucket and cams not attached then I'd certainly wonder.
PS - thread tap you'll need to order as it's a special size. 11M X 1.25 thread pitch and I paid $10.
DougM
