Hi All,
I need to ask the cruiser gurus' a question about the Vac System!!
I have a BJ74 so you know what model I'm talking about.
I have had an intermittent problem with the Cruiser for some time now. Symptoms have been the engine not turning off and a stiff clutch. Then more recently the brake pedal has been hard and 4WD is now not engaging.
First I thought the vacuum tubing might be the prob. Replaced it and no joy. Then I suspected the vac pump that runs off the back of the alternator (I hope its not this!!
Today when i was staring under the bonnet and contemplating life and vac systems i noticed that the brake master is oozing fluid. I've noticed that the brake fluid level has been ever so slowly dropping since I've had the cruiser (18 months). I have been topping it up every few months. Soooooo... I have come to the conclusion that the brake system is leaking/cuctus....duh. If the brake system is leaking fluid i spose it would also leak air/vacuum. So it is my hope that if I replace the brake master and booster all my other problems will be solved.
Have any mudders had any experience or have info on this problem? I'm going to replace the master and booster anyway but if I could get some opinions on the problem and any fixes that would be awesome and I would be eternally gratefull.
Cheers,
Gav.
please discuss......
).Today when i was staring under the bonnet and contemplating life and vac systems i noticed that the brake master is oozing fluid. I've noticed that the brake fluid level has been ever so slowly dropping since I've had the cruiser (18 months). I have been topping it up every few months. Soooooo... I have come to the conclusion that the brake system is leaking/cuctus....duh. If the brake system is leaking fluid i spose it would also leak air/vacuum. So it is my hope that if I replace the brake master and booster all my other problems will be solved.
Cheers,
Gav.
