Vacuum Switch
What exactly does the vacuum switch do? How do you tell if it is working properly?
Tate's vacuum switc has a prong broken off and I am not sure how to fix, Any ideas?
Thanks,
Russell
Can you solder it back on? I think it is used mainly when you decelarate. I think it is connected to the fuel cutoff switch in the carb. You want it working.
chitown40 said:
Need a little more info as to what year truck, what engine, which vacuum switch... etc.
I thought the same thing, but I'll bet he means the VSV.
I think it is the VSV. It mounts on the inner fender and has four small ports one to the distributor, one to the aircleaner, one to the carb, I cant remember where the last one goes. It has two electrical prongs (well only one currently) . It is a 69 FJ 40 with f engine
This look like what we're talking about?
Thats it except it does not have the large opening on the end. I tested the one that we have and it does not work even after fixing the prong.
