vacuum switch next to ABS relay?
Lillington NC
I have noticed a vacuum switch or something with 3 vacuum ports and wiring coming out the side going into a harness right next to the ABS relay, does anybody know what this is? i can take a picture if needed.
for some reason there is nothing leading to the ports and they are all open
Sounds like the windshield washer fluid diverter valve. Fluid comes in from the pump/tank and out either the front or rear outlet (depending on which one you trigger). They have a known history of leaking or not switching correctly after a number of years. It sounds like your PO may have bypassed it completely.
