I need to know where the best source to run the vacuum on Tate's 40 to power the brake booster. It is a 70 that I have added a booster. Should I split the source for the vacuum t case shifter? Suggestions are welcome.
If I remember my old F engine, there are some ports on top of the intake manifold. Pull one of those out and put a large fitting in there to fit a 3/16 or 1/2 inch hose between the two. Should work great.
I wouldn't split a port to power the brakes as they ought to have a source that remains consistant to avoid driver surprise. There should be two 1/8" NPS (NPT) threaded openings topside of the manifold, one front and one to the rear. There may also be another larger port aft of the carburator on the side of the manifold. Is that the one used for the transfer case? If so I'd use it for the brakes and a different one for the shifter, unless doing so would make for a messy looking hose route.
