Vacuum port through intake.
Texas
This is an information post for search reasons. I recently had my intake off for maintenance and to diagnose an egr insufficient flow, code P0401. The vacuum pass through port was clogged and I drilled it out. Seems a 1/16 drill bit fits the port perfectly. I wasn’t 100% sure that was my only issue so I relocated the vacuum switch under the intake to a more accessible spot for future diagnostics. Clearing the pass through cleared my issue. Hope this helps anyone in the future.
Can you provide more information on the location of this port? I am working with a P0401 code and am stuck. I have two specific questions at the moment: where does the EGR VSV connect to the throttl
Sorry for the delay. If you follow the hose in my picture of the top of the intake you’ll find the through intake port. It comes out of the other side of the intake(not pictured).
Second photo shows the vcv. I relocated mine out from under the intake for further, easier diagnostics.
Hope this helps.
Sorry for the delay in reply.
Mine has this code. I’ll try clearing the port without relocating the vacuum switch and report back.
