Vacuum lines suction source
Hey guys, so my question pertains to all the tubes coming off the 3fe intake hose. Do they receive their air suction from their own source down from each respective tube, or is the suction coming from when the engine sucks in air?
Thanks
In general a gas engine will have no vacuum pump and will produce vacuum when the throttle is closed and not when the throttle is open with a fairly flat curve between. A diesel, by contrast, will require a vacuum pump to run vacuum powered accessories.
It depends which lines you are talking about. The ones that actually come off the intake tube go to the valve cover and IAC valve. The little vacuum manifold that runs inline with the intake tube has three lines. One of the small ones goes between the BVSV and the VCV for the charcoal canister. The large one goes between the front of the intake manifold and the VCV for the charcoal canister. I believe the third small line is for the EGR.
So if the hoses are disconnected, then they won't have any pressure sucking through them correct?
I'm just trying to make the system a little more simpler and less cluddered as I like to tinker and engineer what I can. And if what I come up with doesn't work, I'm more than willing to revert to the stock
No way to make it more simple unless you get rid of your EGR and air pump and disable the EVAP system. If you want to get rid of or disable those items, you can, but you need all those lines for those systems to work properly.
