Ok it was just hanging off. so I wasn't sure where the other end went. yes its attached to the HAC ( Red cap). where is the snap loop usually?If your talking about the big hose on the HAC Valve, (red cap) it connects to the bottom of the valve to its pipe and just dangles down on the wheel well through a snap loop.
The bottom of the HAC valve is snapped on and it snaps off. Inside is a filter element that should be cleaned every 10 years or so because it’s always sucking in some air whenever the engine is running - high altitude or low.
That disconnected hose is the feeder for the valve’s air intake.
View attachment 2936746View attachment 2936747
So 87 FJ60 is smogged sort of. the sir pump is installed but deveined and blocked off. The air cleaner ports are blocked off. But all vacuum lines are still installed. So is the HAC even working or doing what's it supposed to?There’s a factory created small hole in the wheel well several inches downwards and back from the bottom of the HAC Valve location. There originally was a little plastic retaining loop in that spot that guided the HAC breathing hose in that direction so it doesn’t flop around.
It was a loose fit. Hose easily slips into it.
You could make something similar with zip ties or something.
These are the straps (similar)
20 Cable Strap Push Mount Wire Tie Nylon Clip 185mm Length For Toyota 82678A9006 | eBay
Releasable Cable Strap. Black Nylon. Overall Length: 142mm (5-1/2"). For Honda Replaces 90672-SA0-0030. For Mazda Replaces 9928-91-053. To most countries.www.ebay.com
