Vacuum Hose help needed
KX TN
I have a ‘93 that needs new vacuum hoses. I’ve searched but have be unable find any info on the sizes used, approximate length needed for each size, and best place to get quality hose.
Also, is there a resource that lists factory part numbers? I’m also in need of sourcing some replacement electrical connectors/ pigtails. Several of the originals are broken.
Thanks for any help you can provide to a newbie to 80 series.
Check on a site called Partsouq. Type in your VIN number and you’ll find everything you need. Also not related to you question but just in case you don’t know, you can find the FSM in the resources section. It’s a must. Cheers.
1.5 seconds of searching the internets and amazingly this is what I find:
Thanks. Putting in my vin was the missing key I didn’t try before on that site.
As far as the vacuum hoses are concerned, I was hoping to fine out the inside diameter of the various hoses, so I could go over to Napa and get some locally. I only see the length on that site but not the inside diameter or pipe sizes.
OGBeno gave you all the part numbers you need, small and easy search on internet with those p/n will give you the info.
The dealer can get you a yard of the correct stuff next day, for next to nothing. Stay away from Napa, your truck doesn't like it there.
90999-92004
I got the 1300mm version, and on my 93/94, under the upper plenum, I pulled the old hoses and matched length piece by piece and the 1300mm length was not enough to replace all the pieces under that plenum. Additionally, there is a hose needed that is larger, plus a different hose that seems to have an outer foam core
also, that 1.5 seconds of searching gave the 1995 version (OBD2), and the poster has a 1993 (OBD1)- and these are slightly different - just not sure if the difference shows up in the vacuum hoses
