Vacuum connection help.....
Tucson
Hi, you all. I'm new here, and its my first post. I have a 72 body on a 69 chassis, with a 2f out of a 78 under the hood. I'm running specter headers and a Holley 350 (I like the performance range from sea level to about 10000 ft, where I hunt elk. When I built the engine I put in a cam from Downey that gives me a little better low end torque.
My question is, I am replacing the stock distributor (originally out of the 69 F engine), with an electronic from a 78-82. My lc has no emission crap on it at all (all it has to do is pass the idle test), and I would be interested in knowing the best hookup for the vacuum ports that come off the diaphragm on the distributor. Also curious as to if anyone actually uses the ones off the top of the distributor.
The only place you can hook up your vacuum advance is to ported carb vacuum. Just determine which port on a holley provides this.
AFAIK, everyone hooks up the vents on the cap. No reason not to, and every reason to if yu ever do any water crossings or for that matter just to avoid condensation collecting in the cap from.
Mark...
