Vaccum Shift Question
Raleigh, NC (Outside the Beltline!!)
I got a '70 40 w/ 3 on the tree. It seems to shift fine when it's cold but after I have driven it for about 15-20 minutes, when I shift into second and third, the motor revs up when I press the gas but it won't accelerate with the motor. My guess is I have a vaccum issue somewhere that only happens after the tranny gets warmed up. Any ideas on how to solve this problem or is this common with those vaccum type shifters. It's no speed demon I know but it just won't keep up with the motor.
I'm not sure I'm following you here :confused: the transmission shifter is a mechanical linkage from the column to the tranny. The vaccum shift is for the transfer case and I think is mounted either on or under the dash on a '70 model.
After the motor & tranny warm up and you shift into 2nd and/or 3rd the motor revs but you don't go, correct. When it starts acting up do you smell or hear anything unusual? I sorta sounds like a clutch issue to me.
you are probably right about the shifter. I thought it was a vacuum shifter since the transfer case was. Anyways, once it starts doing that, i don't get and weird noises or smells. It shifts fine from gear to gear. I have no idea other than that, does the clutch need to be adjusted or something?
What albee said! When I smoked my Centerforce clutch (my fault, being stupid) it acted the same way, except with lots of smoke and asbestos smell. You may be able to adjust it but probably not. Complete clutch kits aren't that expensive anymore if you can do it yourself or with a couple buddies.
great, thanks for the info. It probably is the clutch but no more than I drive it, it's really not an issue. I'll have to check it out this weekend. Thanks guys
Who's a good supplier for the clutches?
rogersfj401969 said:
the clutch disk i thought were the same ...Extreme Clutch Disc 2/3 of the way down the page i would bet its a centerforce http://www.sor.com/sor/cat018.tam?xax=27139&page.ctx=cat018.tam
I saw those the other day...the disc 'frame' is the exact same color as the Centerforce disc I just picked up for my sm420 swap. They were about the same price and I wondered then if it was a Centerforce disc.
