I just replaced the holley two barrel on my '77 2f back to an asian. It runs good but it seems to run a little rough so I started messing with the timing. The first thing I noticed was there was no vacuum advance line going to the dizzy. I pulled the dizzy out and there are threads for some type of fitting. Was this a hard line at one time that was supposed to hook up to the carb? If so, where did it hook up and where can I get one?
The engine seemed to run fine after the timing was set. Showed 650 rpms and about 40 degree dwell angle. It ran fine down the road. I can't see where a vac advance would help me much. Any thoughts? Thanks Matt
