V8 motor mount location
Hollister, CA
Just removed my F motor and installing a V8...anyone have good locations on the mounts when Ive got a 350/sm420/stock TC?? Or maybe a link or book that would give good advice before I learn the hard way? Im also putting in the t-case mount, so Im basically suspending EVERYTHING at once and trying to get it right on the mount sfor the motor AND t-case at the same time. Am I nuts or is there a better way?? Thanks for any advice!!
There is no magic measurement. You have to mock the engine, tranny and xfer in the frame rails and measure. Take in consideration how far the fan is to the radiator, dist clearance to the firewall, where the tranny shifter will come out, driveshaft lengths and clearances, clearance from the steering shaft if you are going saginaw P/S conv., and oil pan clearance from the front axle. Make sure the engine sits level. Take your time on this part, if you do it right you will have a fit that looks like it came that way form the factory.
Take a look in the tech section. A couple of the SBC installation give locations to help get you started. Jack Rices's comes to mind but he had a NV4500 a bit longer than what you are installing so you might be able to go a bit further back. I used his starting point and with a serpentine belt set-up I have 4" clearance to the radiator. just enough room to squeeze an electric fan in. You need to decied what kind of fan you going to use , make sure there is room for it and build back from there....
Nocents
