v6 spool
i came across a v6 spool but i have a 4 cyl truck can i make it work? does sombody make a carrier bearing for that sort of thing?
Don't quote me on this but I believe the difference between the v6 and 4cyl diffs is the bearing sizes and the gusseting on the housing so I think you'd be ok. I'd check with marlin or anyone that deals with a lot of ring and pinion/locker installs to get a more solid answer than that though.
the v6 spool will not work in a 4cyl carrier the bearings are bigger for the v6 spool and will not fit . sorry for the bad news.
