V-8 Swap Interior questions
For all that have done a V8 swap in an 80, were you able to keep the factory shifter council or did you have to remove it and place a aftermaket shifter on the floor? Please state motor type and trans used.
In addition what did you do for gauges? Figure out a way to connect the factory tach, spedo, voltage, oil, and fuel gauges?
Pics greatly appreciated.
'91 FJ80, swapped in 350 TBI mated to stock Toy transmission using Mark's Adapter.
- Stock console and shifter is unchanged.
- Tachometer works using tach signal modifier kit available from Marks.
- Stock oil pressure switch is retained using adapter from Mark's.
- Volt gauge needs nothing.
- Fuel gauge is unchanged.
- Speedo needs nothing.
I used my stock shifter console with a 700R4. I used a Lokar linkage kit and had to move the lever from the right side of the shifter to the left side. I have pictures of it on my build thread here
https://forum.ih8mud.com/diesel-tech-24-volts-systems/184299-94-fzj80-6-2-conversion-begins.html
The pictures of the shifter mod are on the first page I think.
The Lokar kit is really nice, it allows you to adjust it where the shifter actually lines up with the numbers on the console. What year is your Land Cruiser? What transmission are you using? If you are going with a 700R4 and don't have a 91-92 Cruiser then you should get a console from a 91-92 because I think it has markings for 4 gears (L-2-3-D) I didn't switch mine over and it worked fine but it would be cool to have a spot for every gear.
Rusty
