Using Hazard Switch as a driving light switch
Mt. Prospect, IL
Does anyone know what connections I need to use on the back of a Hazard switch if I want to use the switch to turn on and off my driving lights? I also have a defrost switch of that would be easier to hook up.
I don't know if you can use the hazard switch as driving light/fog light switch but I have seen the defroster switch as Fog/Driving light switch though.
I use a hazard switch for Hella 700FF's. I don't use the relay and I wired it straight from the battery with an inline fuse. I don't remember which prongs to use on the hazard switch though. I think they were on opposite ends of the switch.
Do you still have your 80 by chance? If so, maybe we can trace it to find out which pins can be used to make the hazard switch as driving light switch.
I just looked. It the outer pin on each end.
Bill, since we are already on the topic, can you find out which one is the negative and which end is the positive? This will help the OP a lot for his project. Thanks bro.
I'm just using it to interrupt the circuit. Only positive is used. Negative goes straight from the ground by the battery then to the lights. Positive goes from the battery to the fuse then to the to switch, then out the switch to the positive light terminal. I'm using an empty panel to the left of the steering wheel. I'll take pictures tomorrow when there is light.
the two bent prongs on the ends are what you use
here it is hooked up
