Wondering if anyone has come across the issue I'm having with trying to setup the VCM-101 Dakota Digital box for cruise control. The issue is that the 6L80 does not seem to output a speed signal to the OBDII port. I first ran into this issue when trying to get a speed signal out of the OBDII port while doing a dyno tuning session. The guy operating the dyno could not find a speed signal and mentioned that he had never come across this problem with a LS3 and 6L80E connect and cruise setup. Anyway, the vehicle runs, drives and shifts fine and I'm getting the speedometer signal from the transfer case so it's not an issue except for trying to get the VCM-101 to work. I have it configured to get the speed signal from the OBDII but it's not getting any signal. Can I tap into the Toyota speed sensor on the transfer case and run a wire to the "speed" input on the VCM-101? If so, which wire would be the correct one. Thanks in advance for any advice
