used winch questions
Coquitlam B.C.
i have found a few of used used winches and cant decide .
a warn 8274 $300 the access cover where the little plastic knob that you pull out to put it in free spool is cracked and needs to be replaced or repaired .
a warn m8000 $400 obo , no remote or fairlead .
a warn 5687 $300 obo the grand daddy of the 8274 http://www.ih8mud.com/tech/oldwarn.php
the 8274 and 5687 are big assed heavy winches but have 150 ' of cable , the m8000 only hold about 80 ' of cable ?
yes i was think about it as well , i have spent way too many hours scouring the net and the 8274 seams to be the one every one recomends , the only problem is the shaft for the clutch/ free wheel selector is likley bent as the guy tipped it over while dragging it out of his garage right in front of me :eek: , all though that will bring the price down he said make me an offer , i was looking for somthing i could just bolt right up , i am sure i could fix it .
8274 for sure
8274 is always a good choice.
Warn sells every little widget for their winches.
When you know what part needs to be replaced, call a local Warn service centre.
I've had good luck with Drive Products, I'm sure there are others out there as well.
GG
I have one of those 5687's. I would only use it on a resto
go 8274!!
