I found a better handling compromise using variable effective spring rate putting air bags in front and rear, and left the swaybars with the stock rubber. This massively decreased roll, and allows a lot of ability to tune the suspension without reducing effective wheel travel. The biggest issue with eurethane (esp in swaybars) is their propensity to limit wheel travel causing premature lift - more effective bar = less wheel travel before wheel lift. One of the advantages of awd, is keeping 4 wheels planted. Why a lot of hardcore offroaders disconnect the swaybars.
HTH
Scott J
94 FZJ80 Supercharged
I have wanted to use airbags for years on my FJ-62, do you have
any links on the set up a 62?
I never go off-road (gasp!!) with my FZJ-80; it is my 80mph highway
cruiser, so I like a smooth but controlled ride; now have Bilsteins
and Michelin CrossTerrain SUV tires. I want more control, but not
more vibration; I would like to talk to someone who has put some
"soft" urethane bushings in, like Energy Suspensions HyperFlex.
They make all the standard sizes that you can order individually,
but do not have a "kit", yet.
I noticed my 80 has a bit too much lean in the corners and is getting
a tad sloppy on the highway, but just a tad; I shouldn't complain,
as it handles better than other brand new, but lesser, SUV's,
I just like a tight suspension/steering.
When my FJ-62 hit 200K, I replaced all my spring bushings with
Energy Suspension Urethane bushings as I was wandering all over
the road, the OEM rubber was all worn out; and that was like 12 years ago; it still rides like it is on rails; tracks perfectly.
From my experience; the cheapest way to tighten up a suspension
or fix wandering steering is replacing worn out (rubber) bushings.
G
