I find any satisfaction in the hardcore section for my question so I'll bring it back here.
Does anyone have a setup for retaining their springs and if so can you share?
I have done some research and yes, I have seen the pics of the Shortbus and how Christo retains the lower wind on the springs but not the top. Just the same I'm interested in how other's have solved this issue. Thanks.
Why do you want to retain the top? You may shorten spring life for no other benefit (the spring is not going to act like a limiting strap).
Have you ever seen a stock setup on a Jeep for axle end spring retention? It is a simple little clip. You need the same sort of thing that would be very easy to fabricate.
What springs/shocks are you running where you have an issue of too much unseating at full droop?
To ensure when the spring does reach full extension the axle doesn't unload and to more securely mount the spring. On the 80's setup this may not be as much an issue as say a Disco that doesn't have the bump stop located inside the spring.
That's just it, if the spring is securely retained top and bottom it will act as a limiter. Consider a leaf spring, it will only allow X amount of droop and that's it because it is retained on both ends. Before there is talk of apples and oranges the end result is still fruit juice. The same is true of a retained coil spring. How can stretching a spring the small amount you'd have at full extension do any harm to spring life? That's hog wash. Stretch a click-type pen's spring even 50% and what happens, it goes back to it's steady state. There is more irreversible damage (sag) done to the spring by every day driving and parking than the short time period the spring would be extended.
Yes, and I have seen the clip fail on several occasions and the springs fall out at full travel. I agree they are easy to fab. A simple 90* bracket welded to the center and side edge of the lower mount as on the Shortbus.
OME heavy and the shocks are TBD. My intent is to use the currently installed springs and revamp the shocks and shock mounts as needed to attain more extension and even out overall travel, much the same as your FOR setup has done.
I understand the horse has been beaten long past dead and dried regarding down travel on the front but my goal for the front and rear is not to be limited by the shock travel rather by suspension geometry and the springs. It's great there are companies and individuals out there that are designing suspension systems for the 80, however many people have already sunk $$$ into their current setup and the $$$$ spent on another high dollar kit could be better utilized on other projects. I want to find the middle ground where the truck can function as a DD and still wheel really well. I have no intention of getting carried away on a one-off suspension setup that I have to trailer to the trail head. If/when I get that interested in hardcore stuff I will build another truck for that purpose.
IBCRUSN, on the Shortbus I have adjustable spacers on the front, so that is different from stock. I tapped the collar of the spacer and bolted on a a J plate. Kinda like a J bolt but out of flat steel.
On the rear I have 1.5" Aluminum spacers, They are just about as high as the spring retainer tower. I just used a flat plate accross that to hold the spring. I have access to the top of the spring buckets, so it might not work for stock.
I would also say that repeatedly compressing springs until the coils touch is much more damaging than the little over extension you will get. However I have run the shortbus with shorter springs than needed and spacers with the coils retained and I have no unloading when you don't want it. Made the world of difference in stability when rock crawling.
Christo,
Thanks for your input. I've seen the pics of how you retain the springs at the axle, do you have any of the uppers? I can picture/understand the rears and I think with the body lift installed I have room to play with. Maybe something similar or possibly two J pieces welded to threaded material and bolted through the top of the tower 180* opposite each other. The front requires a little more thinking since I don't plan on getting that crazy with adjustable spacers and all. I should have Beno's spacers (FZJFillmore's IIRC) at some point in the future.
I am finally getting around to doing this as soon as the snow melts - truck won't fit in the shop anymore... I'll post pics.. with what I come up with for the tops on stock. I am probably going to just go with the axle stops, and do a plate with a bolt.. or just weld them in all around.. (the retainers)
