upgraded sway bar link LH for 2" or more lift== Looks like a good idea! Anybody have one?
Pensacola, Fl.
DESCRIPTION
Roadsafe offer a range of upgraded extended Sway Bar Links for the Patrols and extensions for the 80/100 series Cruisers. If your Sway Bar is out of alignment, handling can be affected. Realign your sway bar with Roadsafe Sway Bar Links & Extensions.
SPECIFICATIONS
  • Suits Lift: 2”+
COMPATIBILITY
  • Toyota Landcruiser 200 series with KDSS (LH Rear – 50mm dropped forged)
or this Roadsafe RH LH Extended Rear Sway Bar Link for Landcruiser 200 series with KDSS
Delivery Estimator
Add to basket
Roadsafe Sway Bar Relocation Brackets Toyota Landcruiser 200 STBR002k
COMPATIBLE WITH LANDCRUISER 200 KDSS (94.5/96mm HOLE C/C - 26.5mm Relocation)
Roadsafe Sway Bar Relocation Brackets Toyota 200 series Landcruiser
Part Number -STBR002
Used when you lift your Landcruiser higher than 2" it is strongly recommended to fit a sway bar Relocation Plate to the front sway bar.
Availability: In stock
Only 3 left
$85.00
Qty:Add to Cart
Be the first to review this product
Email to a Friend
Share
